WP76xx Firmware Release 16.0.1 Components
  • May 23, 2022
  • Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.0.1 components and how to download it on your product.
WP76xx Firmware Release 16.0.1 combined image
Modem Firmware (Generic — GCF & PTCRB)
SWI9X07Y_02.37.03.00 / 002.095_003
Modem Firmware (AT&T  — PTCRB)
SWI9X07Y_02.37.00.00 / 002.098_003
Modem Firmware (Sierra Wireless — GCF)
SWI9X07Y_02.37.03.00 / 001.060_003
Modem Firmware (Sprint — GCF)
SWI9X07Y_02.37.02.00 / 001.027_003 Download
Modem Firmware (T-Mobile — PTCRB)
SWI9X07Y_02.35.02.00 / 001.017_001 Download
Modem Firmware (Verizon — GCF)
SWI9X07Y_02.37.06.00 / 002.107_003
002.015
SWI9X07Y_02.37.10.02
19.11.2
 Legato Source Release #
19.11.2 Source
 R16.0.1 (Based on Kernel 3.18.140 and Yocto 2.5)
SWI9X07Y_02.37.10.02 Source
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example"  and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
  2. Select the "Target Menu".
WP76xx Firmware Release 16.0.1 Components | Source
