WP76xx Firmware Release 16.1 Components
  • Jul 20, 2022
  • Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.1 components and how to download it on your product.
WP76xx Firmware Release 16.1 combined image
Modem Firmware (Generic — GCF and PTCRB)
SWI9X07Y_02.37.03.05 / 002.115_002
Modem Firmware (AT&T)
SWI9X07Y_02.37.03.05 / 002.126_000
Modem Firmware (T-Mobile)
SWI9X07Y_02.35.02.00 / 001.017_001
Modem Firmware (Verizon)
SWI9X07Y_02.37.06.00 / 002.107_003 Download
Modem Firmware (DOCOMO)
SWI9X07Y_02.28.03.05 / 001.024_001  Download
Modem Firmware (KDDI)
SWI9X07Y_02.28.03.05 / 001.026_002
Modem Firmware (LGU)  SWI9X07Y_02.32.03.01 / 001.026_001   Download  Custom Modem Firmware can NOT be created by customers
Modem Firmware (SoftBank)  SWI9X07Y_02.28.03.05 / 001.028_001   Download  Custom Modem Firmware can NOT be created by customers
Modem Firmware (Telstra)  SWI9X07Y_02.28.03.05 / 001.058_001   Download   Custom Modem Firmware can NOT be created by customers
002.015
SWI9X07Y_02.37.10.02
19.11.6
 Legato Source Release #
19.11.6 Source
 R16.1 (Based on Kernel 3.18.140 and Yocto 2.5)
SWI9X07Y_02.37.10.02 Source
  2. Select the "Target Menu".
