WP76xx Firmware Release 17.1 Components
Jan 28, 2026 - Author: Sierra Wireless - Version 1 - 370 Views
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 17.1 components and how to download it on your product.
WP76xx Firmware Release 17.1 combined image
Modem Firmware (AT&T Data)
SWI9X07Y_02.37.06.25
 / 001.001_000
Modem Firmware (AT&T VD)
SWI9X07Y_02.37.06.25 / 001.003_000
Modem Firmware (Generic Data)
SWI9X07Y_02.37.06.25 / 001.002_000
Modem Firmware (Generic VD)
SWI9X07Y_02.37.06.25 / 001.003_000 Download
Modem Firmware (Verizon Data)
SWI9X07Y_02.37.06.25 / 001.000_000 Download
Modem Firmware (Verizon VD)
SWI9X07Y_02.37.06.25 / 001.004_000
Modem Firmware (T-Mobile Data)  SWI9X07Y_02.37.06.25 / 001.000_000  Download   Custom Modem Firmware can NOT be created by customers
Modem Firmware (T-Mobile VD)  SWI9X07Y_02.37.06.25 / 001.000_000 Download  Custom Modem Firmware can NOT be created by customers
Modem Firmware (KDDI)  SWI9X07Y_02.28.03.05 / 001.026_002   Download  Custom Modem Firmware can NOT be created by customers
Modem Firmware (SoftBank)  SWI9X07Y_02.28.03.05 / 001.028_001 Download   Custom Modem Firmware can NOT be created by customers
Modem Firmware (DOCOMO)   SWI9X07Y_02.28.03.05 / 001.024_001  Download   Custom Modem Firmware can NOT be created by customers
002.015
SWI9X07Y_03.01.14.00
21.05.5
 Legato Source Release #
legato-21.05.5.tar.bz2
 R17.1 SWI9X07Y_03.01.14.00 Source   Open Source Licenses 32-bit ToolChain
  2. Select the "Target Menu".
©2026 All rights reserved
