WP76xx Firmware Release 8 Components
  • Mar 1, 2018
  • Version: 8
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 8 components and how to download it on your product.
WP76xx Firmware Release 8 combined image
SWI9X07Y_02.14.04.00 / 002.025_000
SWI9X07Y_02.10.01.00 / 002.015_001
Modem Firmware (AT&T)
Modem Firmware (Verizon)
SWI9X07Y_02.10.00.00 / 002.014_002
002.007
18.01.0
18.01.0 Source
SWI9X07Y_02.14.04.00 Source
(Based on Kernel 3.18 and Yocto 2.2)
    • MCU Firmware: mcuFW.cwe
