WP76xx Firmware Release 9 Components
May 02, 2018 - Author: Sierra Wireless - Version 9 - 4954 Views
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 9 components and how to download it on your product.
WP76xx Firmware Release 9 combined image
SWI9X07Y_02.16.02.00 / 002.032_000
SWI9X07Y_02.10.01.00 / 002.015_001
Modem Firmware (AT&T)
Modem Firmware (Verizon)
SWI9X07Y_02.10.00.00 / 002.014_002
002.009
18.03.0
18.03.0 Source
SWI9X07Y_02.16.02.00 Source
(Based on Kernel 3.18 and Yocto 2.2)
    • MCU Firmware: mcuFW.cwe
©2026 All rights reserved
