    Configuring Web Settings
    The Web Settings allow you to configure how local clients connect to the router, and to configure what users see on the AirLink OS login screen.
    Under Services > Web, you can configure the AirLink OS Web settings as shown below.
    General Settings
    The following settings configure how devices and users can connect to the router’s AirLink OS configuration through a LAN connection.
    These settings do not enable remote access to the router. Semtech recommends AirLink Management Service or AM/AMM for remotely managing AirLink routers.
    HTTP ACCESS Configure HTTP AirLink OS access Enable, Disable, Redirect to HTTPS Redirect to HTTPS (RECOMMENDED)
    HTTP PORT Configure HTTP port for AirLink OS access 1 to 65535 80
    HTTPS ACCESS Configure HTTPS AirLink OS access Enable/Disable Enable
    HTTPS PORT Configure HTTPS port for AirLink OS access 1 to 65535 443
    HTTPS CERTIFICATE If using HTTPS, click to select and/or create a security certificate. See Security Certificates Documentation here on how to create a PEM certificate. For HTTPS, only a certificate and private key is required. Certificate, private key and root can be used, but root will be ignored. Root only certificates will not work. N/A N/A
    HSTS HTTP Strict Transport Security Off/On On
    Session Settings
    SESSION IDLE TIMEOUT The amount of idle time required before the user is automatically logged out and redirected to the login screen. 1 to 1440 mins 5 mins
    MAXIMUM LOGIN ATTEMPTS The number of failed login attempts allowed before the user account is temporarily locked for the length of time specified in UNLOCK TIME. Disabling this feature is not recommended. 0 (disabled) to 5 3
    UNLOCK TIME The length of time that the user account is locked after the maximum number of failed login attempts. 1 to 3600 seconds (1 hour) 120 seconds (2 minutes)
    Remote Authentication Settings
    LDAP Client Settings
    To configure LDAP:
    1. Go to Web > Authentication > LDAP CLIENT.
    2. Click the blank field, and then click CREATE.
    3. In Create Server, configure the settings described in the table below.
    4. Click CREATE.
    The server you configure here will also appear under System > User Accounts > LDAP.
    LABEL Required name for the LDAP server N/A N/A
    SERVER Required LDAP server IP address or resolvable domain name N/A N/A
    PORT Port number 1 to 65535 389
    TIMEOUT
    The time limit for the server to respond.
    Note: If the server does not respond during the timeout, the authentication fails and the next enabled authentication mechanism checks the credentials.
    1 to 60 seconds 30 seconds
    ENCRYPTION Encryption type.
    • Off: None
    • On: SSL (Secured Sockets Layer protocol) - Non-standard legacy (pre-LDAPv3) encryption type
    • start_tls: Secure mechanism integrated into the LDAPv3 protocol (RECOMMENDED)
    start_tls
    BASE DN The Base DN is the path in the LDAP tree to the list of users (for example, dc=semtech,dc=com). This is where the LDAP protocol searches for a matching user to authenticate. N/A N/A
    BIND Choose how the LDAP search is done
    • anonymous: A password is not required to perform requests in the database
    • explicit: A password is required to perform requests in the database
    anonymous
    BIND DN
    This setting is available when BIND is set to explicit.
    Enter the full path of the user authorized to perform requests in the LDAP database (for example, cn=admin,dc=semtech,dc=com)
    N/A N/A
    BIND PASSWORD
    Enter the password associated with the Bind DN user.
    N/A N/A
    RADIUS Client
    To configure RADIUS:
    1. Go to Web > Authentication > RADIUS CLIENT.
    4. Click CREATE.
    The server(s) you configure here will also appear under System > User Accounts > RADIUS. The server(s) will also be available to select as primary and backup RADIUS authentication servers for a Wi-Fi access point using WPA2-Enterprise security mode.
    LABEL Required name for the RADIUS server N/A N/A
    SERVER Required RADIUS server IP address or resolvable domain name N/A N/A
    PORT Port number 1 to 65535 1812
    TIMEOUT
    The time limit for the server to respond Note: If the server does not respond during the timeout, the authentication fails and the next enabled authentication mechanism checks the credentials.
    SECRET Shared secret for configured server N/A N/A
    TACACS+ Client
    To configure TACACS+:
    1. Go to Web > Authentication > TACACS+ CLIENT.
    4. Click CREATE.
    The server you configure here will also appear under System > User Accounts > TACACS+.
    LABEL Required name for the TACACS+ server N/A N/A
    SERVER Required TACACS+ server IP address or resolvable domain name N/A N/A
    PORT Port number 1 to 65535 49
    TIMEOUT
    AUTHENTICATION PROTOCOL The type of bind used for authentication
    • PAP: Password Authentication Protocol
    • CHAP: Challenge Handshake Authentication Protocol. The stronger of the two protocols. Recommended, provided it is supported by all the client devices.
    • Login: User name and pasword
    PAP
    Editing or Adding Remote Authentication Servers
    After you have configured a remote authentication server, you can click to edit the configuration.
    You can also add another server configuration by clicking (Clear), clicking the empty field, and then clicking CREATE.
    If multiple servers are configured, you can select a different server by clicking (Clear), clicking the empty field, and then selecting the desired server.
    To delete a server, you can click to edit the configuration and then click DELETE at the bottom of the Edit Server page.
    You cannot delete the server if it is being used elsewhere in the router configuration. For example, it may be part of a Wi-Fi interface configuration. To delete the server, you must first disable it where it is being used in the router configuration.
    SETTING DESCRIPTION
    LEGAL TEXT INSIDE LOGIN ZONE This will display the text inside the login zone under the SIGN IN button
    LEGAL TEXT OUTSIDE LOGIN ZONE This will display the text outside the login zone
    Example:
