    The AirLink XR80 has two SIM card slots that support the cellular interface. By default, the SIM card in the upper slot (slot 1) is the active SIM card.
    The XR80 also has an LPWA Cellular interface, equipped with a Sierra Wireless Ready to Connect (R2C) eSIM, that provides a connection to AirVantage.
    Table of Contents
    Cellular Configuration
    • ENABLE
      • Initializing: initiating communication with radio
      • Initializing SIM: Handling SIM-related tasks
      • Check Radio Carrier: Checking the carrier of the SIM card inserted against the “Network Operator Switching” setting (whether it is automatic or a specific carrier is selected)
      • MultiApn: Checking Multi APN configuration
      • Connecting
      • Connected
    • NETWORK OPERATOR SWITCHING: By default, the router automatically selects the network operator (radio module firmware). To force the router to use a radio module firmware for a different carrier, change NETWORK OPERATOR SWITCHING to Manual, and then select a Network Operator from the list.
      • Automatic: The router automatically selects and uses the appropriate radio module firmware for the active SIM card. (default)
      • Manual:The router does not automatically select the appropriate radio module firmware when it is powered on or rebooted. You must select the Network Operator.
    • ACTIVE NETWORK OPERATOR
    • MIMO: The XR80 supports Multiple Input/Multiple Output (MIMO) for improved throughput and signal quality, and requires additional (up to 4) Wi-Fi antennas. Select the option that matches the number of antennas connected to the XR80. Note that 5G band N41 is disabled in MIMO 1x2 mode.
    • SIM CONFIGURATION NAME: By default, the current SIM cards in use and their associated configuration are included in the SIM Database. You can enter a name for the SIM Configuration in this field. The name appears in the SIM Database.
    • PREFERRED TECHNOLOGY: Restricts the router to using a specific cellular technology: Auto (default), 3G Only, 4G Only
    LPWA - Out-of-Band Management
    • ENABLE: Turn the LPWA interface on or off
      • Initializing
      • Initializing SIM
      • Configuring
      • Connecting
      • Connected
      • Standby
      • Wait For Update
    • MTU: The MTU Transmission Unit in use
    Multi-APN Configuration
