The router can act as a Virtual Private Network (VPN) device, providing enterprise VPN access to any device connected to the router even when a device has no VPN client capability on its own. The router supports up to five simultaneous IPsec VPN tunnels. The IPsec implementation is fully IKEv1 and IKEv2 compliant, and supports MOBIKE when operating over IKEv2. The AirLink OS VPN implementation also provides the option to configure IPsec tunnels to FIPS (Federal Information Processing Standards) mode.
You cannot create a firewall rule that applies to outbound/inbound traffic inside an IPsec tunnel.
You can configure the XR Series router as a VPN client or VPN server. The table below outlines how the router operates in each mode.
| Overall relationship | Master – sets all details for connection, for all clients. AirLink XR Series routers running AirLink OS can support multiple clients connected simultaneously and are limited only by the throughput requirements of those clients. | Slave – must match the defined details for a single connection as defined on the target server |
These are the settings you’ll find in the Basic Configuration Steps described below.
| MODE |
Client | Client, Server |
| LAN/HOST MODE |
LAN | LAN, HOST |
| CLIENT VIRTUAL IP TYPE | Appears when the tunnel is being configured for Client/HOST mode. Selects how the virtual IP address is assigned. In most applications, this is left at Automatic. | Automatic | Automatic (requests a virtual IP address from the server), Static |
| VIRTUAL IP ADDRESS |
n/a | n/a |
| MOBIKE |
| CERTIFICATES |
n/a | n/a |
| PSK |
n/a | n/a |
| REMOTE SUBNETS |
n/a | n/a |
| EXEMPT SUBNETS | List of Remote Addresses or subnets to be exempted. Traffic passing through the router to the IP addresses (or Fully Qualified Domain Names (FQDNs)) in this list is sent directly to the Internet (it is not sent through the IPsec VPN tunnel). | n/a | n/a |
| LOCAL AUTHENTICATION ID | You can enter the Local Authentication ID as a text string to identify the router as a VPN client. The Local Authentication ID must also be configured on the remote VPN server (the Sierra Wireless ACM, for example). Alternatively, you can leave the Local Authentication ID blank to use the default WAN IP address. The default WAN IP address would also need to be configured on the remote server/ACM. | n/a | n/a |
| WAN INTERFACES |
Select the WAN interfaces to use for this tunnel, in order of priority (first to last/left to right). The order specifies the sequence of failover if the highest-priority WAN interface loses connection. You can select default to have the tunnel use the default WAN zone. In that case, the default WAN priority of Ethernet, Wi-Fi and Cellular applies. Please note that even when default is not selected, the tunnel will use the default WAN interface if no other configured WAN interface is available. |
| DEAD PEER DETECTION (DPD) |
Dead Peer Detection (DPD) verifies the status of the active connection, and can be configured to take action if the primary/active VPN tunnel goes down. Possible actions when DPD detects a failed connection are: * Restart (default): The router restarts the current IPsec tunnel. * None: The router takes no action. * Failover: The router begins using the SECONDARY PEER FOR FAILOVER. For more information, see VPN Failover. |
n/a | n/a |
| DPD INTERVAL (SECONDS) | Sets the DPD interval (in seconds). If there has been no traffic during this interval, after five retries (each with an interval of 30 seconds by default) the router takes the DPD action configured above. | 30 | 30 - 3600 |
| IKE REKEY TIME (SECONDS) | Sets how long the VPN tunnel is active, in seconds | 7200 | 60 - 32000000 |
| IKE DIFFIE-HELLMAN GROUPS |
dh16 (modp4096) |
| ESP REKEY TIME (SECONDS) | Sets how long the VPN tunnel is active, in seconds | 7200 | 60 - 32000000 |
Click CREATE IPSEC TUNNEL.
Click CREATE.
To use VPN failover to help maintain your VPN connection, set DEAD PEER DETECTION (DPD) to Failover, and configure a secondary VPN peer. Dead Peer Detection (DPD) verifies the status of the active connection. For example, if the primary/active VPN goes down (that is, DPD detects that the end device is not responding), you can configure the VPN to automatically switch traffic to a backup VPN tunnel (the secondary peer).
