This page shows you how to configure Wi-Fi for your AirLink XR80 router in Access Point mode and Client mode.
Wi-Fi Client 2.4GHz
The 5GHz AP and Client share one radio, and the 2.4GHz AP and Client share another radio. The interface types cannot be changed — Clients cannot be used as Access Points, and Access Points cannot be used as Clients.
For example:
Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality.
The Wi-Fi antenna bank can have up to 5 Wi-Fi antennas connected. Antenna connectors 1–4 are used for MIMO, and connector 5 is used for scanning 5GHz in Client mode. To enable 5GHz operation, the XR80 must have antennas connected to connectors 1 and 5 (at minimum). See the XR Series Hardware Guide for more information about antennas.
For antenna connectors 1–4:
Enable DFS Channels to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS Channels enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your operating equipment is DFS capable, Sierra Wireless recommends leaving DFS Channels disabled.
The Transmit Power Level setting allows you to restrict transmit power to the Wi-Fi antenna(s). The actual transmit power attained depends on a number of factors including the regulatory domain and the wireless channel used. Generally, a higher transmit power setting results in greater Wi-Fi range for the clients. Set for 100% by default, and adjust for network conditions. If clients are connecting with many other clients nearby, high transmit power can cause interference and impede throughput across connected clients.
Best Practice recommendation: If the 2.4GHz and 5GHz APs are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP adresses when switching between the APs.
For all security modes except OPEN, enter a SECURITY PASSPHRASE of at least 8 characters.
For WPA2 and WPA2-Enterprise security modes only, select the 802.11W option.
Note: The 802.11w options do not appear for WPA3 or WPA2/WPA3 Transition Mode. For WPA2/WPA3 Transition Mode, ‘Optional’ is automatically used. For WPA3, “Required’ is automatically used.
Enable AUTO CHANNEL to have the router choose the channel on which to operate.
The AP and corresponding Client interface (2.4GHz or 5GHz) share a radio and therefore share the same operating channel.
If the Client connects to a remote AP, the XR80’s AP interface switches channels to match the Client.
When the Client disconnects from the remote AP, the radio stays disconnected for 5 scans and then the XR80’s AP switches back to its original setting (AUTO CHANNEL or selected CHANNEL).
Enable AUTO BEACON INTERVAL to have the router send periodic messages (beacons) to advertise its availability. To choose a specific interval, disable AUTO BEACON INTERVAL and then manually enter the required BEACON INTERVAL in milliseconds (100 ms is the default).
Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect.
The maximum value you can enter depends on the interface: * Wi-Fi AP 5GHz supports up to 128 clients (includes clients connected to up to two additional 5GHz SSIDs) * Wi-Fi AP 2.4GHz supports up to 128 clients (includes clients connected to up to two additional 2.4GHz SSIDs)
For example (using the 5GHz radio in the figure below, which is capable of supporting up to 128 clients):
Configured Maximum Total Allowed Wi-Fi AP 5GHz connected Wi-Fi 5GHz SSID 1 connected Wi-Fi 5GHz SSID 2 connected Available Wi-Fi A 5GHz = 128
Wi-Fi 5GHz SSID 1 = 128
Wi-Fi 5GHz SSID 2 = 128128 50 46 0 32 across all three SSIDs Wi-Fi A 5GHz = 30
Wi-Fi 5GHz SSID 1 = 20
Wi-Fi 5GHz SSID 2 = 1060 25 20 5 10 across Wi-Fi A 5GHz and Wi-Fi 5GHz SSID 2
(Wi-Fi 5GHz SSID 1 is at max.)
A USE ADDITIONAL SSIDS switch is below the Wi-Fi configuration table.
When enabled, an Additional SSIDS table opens from which you can select, enable, and edit SSIDs (Virtual Access Points — “VAP”s). This allows you to use multiple SSIDs broadcasting on separate LAN segments and configured for different security protocols, if required.
Up to two additional SSIDs can be enabled for each of the access point interfaces (i.e., two for Wi-Fi AP 5GHz and two for Wi-Fi AP 2.4GHz).
A DISABLE APS ON CLIENT ASSOCIATION switch is below the Wi-Fi configuration and Additional SSIDs tables.
To configure this feature:
Tip: Rest the pointer on an SSID to view the channel, BSSID and RSSI for each band.
To use a scanned SSID:
To create an SSID manually:
