Patterns
Solid: Single color, always on
Fast flashing: One color on for 0.2 s, then off or another color for 0.2 s
Slow Flashing: One color on for 0.25 s, then off or another color for 0.75 s
Pulse: One color on for 0.5 s, then a 0.2 s pulse off or another color
Chase: All LEDs on for 0.2 seconds in sequence from left to right, continuously
GNSS
Solid Green
Satellite fix available and Dead Reckoning is enabled and calibrated (Dead Reckoning calibration occurs occasionally during driving and takes several minutes to complete) or
Satellite fix available and Dead Reckoning is disabled
Solid Yellow
Satellite fix is available and Dead Reckoning is enabled but not calibrated
Solid Red
Searching for a satellite fix
Fast Flashing Red
GNSS antenna is open or shorted.
Slow Flashing Red
GNSS antenna is disconnected.
Off
GNSS is off or disabled
WI-FI
Connected in client mode (good signal) with traffic
Slow Flashing Green
Wi-Fi client is enabled but not connected, and no AP is enabled
Connected in client mode (fair signal) with traffic
Connected in client mode (poor signal) with traffic
AP with traffic, and Wi-Fi client enabled but no connection or
AP with traffic, and Wi-Fi client disabled
Off
No Wi-Fi enabled (no AP, no Wi-Fi client)
CELL XP1/XP2
Connected to a 4G/3G network with a good connection (equivalent to 4–5 bars)
Slow Flashing Green
Connecting to a 4G/3G network
Connected to a 5G network with a good connection (equivalent to 4–5 bars)
Slow Flashing Purple
Connecting to a 5G network
Connected to a network with a fair connection (equivalent to 2–3 bars). During activity, RAT (5G or 3G/4G) is indicated by a pulse color:
Green pulse: 4G/3G
Purple pulse: 5G
Connected to a network with a poor connection (equivalent to 1 bar). During activity, RAT (5G or 3G/4G) is indicated by a pulse color:
Green pulse: 4G/3G
Purple pulse: 5G
Slow Flashing Red
No network connection
Off
No expansion cartridge installed
LPWA
LPWA connected to a network and ALMS with a good connection (equivalent to 4–5 bars)
Slow Flashing Green
Connecting to a network
Connected to a network and ALMS with a fair connection (equivalent to 2–3 bars)
Connected to a network and ALMS with a poor connection (equivalent to 1 bar)
Slow Flashing Red
Off
LPWA module powered off
POWER
Solid Green
Router operating normally with ignition on
Fast Flashing Green
Router is rebooting after Reset button pressed for <5 seconds (or reset from AirLink OS)
Solid Yellow
Router is booting or
the router is thermally throttled — one or more of CPU, cellular radio, and Wi-Fi radio has exceeded threshold. When operating temperature returns to normal, LED returns to solid green.
Fast Flashing Yellow
Router is rebooting and being reset to factory defaults, after Reset button is pressed for 20–40 seconds
Solid Red
Power is present, but the router is not running (e.g. ignition is off, router is in standby mode, etc.)
Fast Flashing Red
Router is rebooting and being reset to the specified Reset Configuration Type, after Reset button pressed for 5 to 20 seconds.
Slow Flashing Red
Router is not operating because operating temperature range is exceeded (i.e. thermal shutdown)
Reset button held > 40 seconds, canceling the reset action and rebooting normally when released. (i.e. if pressing the reset button for more than 5 seconds, and you decide that the router should do a regular reboot [not a reset to default template or factory defaults] continue pressing Reset until the LED flashes Yellow and Red)
Off
No power or the router is in standby mode and the AirLink OS Standby LED setting is disabled (System > MCU > Power Management)
All LEDs
A yellow LED chase pattern indicates a software update in progress (a XR router firmware update, radio module
firmware update, etc.)
