    XR Series routers are equipped with location tracking, enabling you to track the movements of a vehicle or other devices that move. The router relays the information of its location as well as other data for use with tracking applications.
    • Computer-Aided Dispatch/Automatic Vehicle Location (CAD/AVL): The router provides real-time location data to the server that tracks the location and other variables of the vehicle or asset.
    • Trimble® ASCII Interface Protocol (TAIP): TAIP is a digital communication interface based on printable ASCII characters over a serial data link. TAIP was designed specifically for vehicle tracking applications but has become common in a number of other applications, such as data terminals and portable computers, because of its ease of use.
    Hardware Requirements
    Ensure that a GNSS antenna is connected to the dark blue FAKRA connector on the router. See the XR Series Hardware Guide for installation and antenna connection instructions. For compatible antennas sold by Sierra Wireless, see our website.
    GNSS is the evolution of GPS. GPS uses only a single constellation of satellites, while GNSS uses signalling from up to 4 constellations to provide a more reliable and accurate location fix. For legacy applications that may require GPS-only, you can limit the location service by selecting the “GPS Only” option. See LOCATION CONSTELLATION below.
    Enabling Location
    • Starting
    • Device Unavailable
    • Waiting For New Fix
    • Location Fix Acquired
    • Firmware Upgrade Starting
    • Firmware Upgrade Failed
    • Firmware Upgrade Complete
    • Preparing Firmware Download
    • Programming Firmware
    • Downloading Firmware [version]
    • Downloading Firmware [percentage]
    Status messages related to Firmware are shown after you manually select new GNSS Firmware for the router to use. See GNSS FIRMWARE SELECTION MODE below.
    When switched to Manual, you can select firmware from the SELECT GNSS FIRMWARE list.
    Manual, Automatic Automatic
    GNSS CURRENT FIRMWARE Current version of firmware on the router’s GNSS (Global Navigation Satellite System) module N/A N/A
    LOCATION CONSTELLATION Location constellation you want the router to use
    • GPS Only
    On (required for active GNSS antenna) Off (compatible only for passive GNSS antenna)
    On
    GNSS ANTENNA DETECTION Enable/Disable the reporting of GNSS Antenna State under Status/Monitoring > Status > Location. When disabled, GNSS Antenna State is reported as Not available. Off/On Off
    Configuring Location Reports
    Under Location > Reporting:
    Local Reporting
    Local reports are sent via UDP to an IP address on the LAN. For Local Reporting, configure the following:
    • Service: UDP Broadcast or UDP Multicast. UDP Multicast needs a Destination IPv4 address.
    • Destination IPv4 Address (Multicast Only): To send the location report(s) to a local LAN client, enter the address here. If there is more than one local client, it is advisable to set up a DHCP reservation or set a static IP address on the client.
    • Destination Ports: Enter the port on which the CAD/AVL application is configured to receive data (65278 is the default). The port should be available from your CAD/AVL administrator or application documentation.
    • Destination LAN Segments: Enter the LAN bridges (network segments) for multiple clients. If you have multiple clients that require the location reports, you can send reports to each client on a particular LAN bridge (network segment).
    • Reporting Interval: Sets how frequently (in seconds; 5 seconds by default) the location report is sent to the LAN or IPv4 destination.
    • Report Type: Select the report type (or protocol, as described above).
      • NMEA
      • TAIP data: TAIP location report that contains PV (Position/Velocity Solution) messages
      • Compact TAIP data: TAIP location report that contains CP (Compact Position Solution) messages
    • Sentences: If the report type is NMEA, you can select the desired combination of GGA, GSA, RMC, VTG, and GSV sentences, along with the Proprietary Device ID. Some typical sentences are below.
    Remote Reporting
    For Remote Reporting, configure the following REMOTE REPORTING SERVER settings, as applicable:
    • Protocol: TCP or UDP
    • Destination Hostname or IP - IP address or FQDN (fully qualified domain name) of the server where location reports are sent. Example: 192.100.100.100. The IP address can be for a local host or a remote server that is accessed over-the-air or via a VPN tunnel. If an IP with the last octet of 255 is configured (i.e. 192.168.13.255), a report would be broadcast to all IPs on that subnet. When configured to a local host subnet, any connected device would receive the report. Note: If you want to use it as a LAN device, it must have a private IP address. If you want to use a public IP address, use a Local IP report.
    • Destination Port: Destination port on the server where location reports are sent. The destination port can be the same for all servers or you can configure a different destination port for each server. Range: 1–65535 (default for the first server is 22335).
    • Reporting Interval: - Sets how frequently (in seconds; 5 seconds by default) the location report is sent to the IPv4 destination
      • NMEA
      • TAIP data: TAIP location report that contains position and velocity
      • Compact TAIP data: TAIP location report that contains the compact position
    • Sentences: For NMEA reports, you can select the desired combination of GGA, GSA, RMC, VTG, and GSV sentences, along with the Proprietary Device ID. Some typical sentences are below.
    2. Go to Hardware Interfaces.
      • PAD MODE: UDP
      • DESTINATION ADDRESS: Same Destination IP Address used in Step 1. For example, 192.168.1.1.
    5. Click SAVE.
    2. Go to Telemetry > Custom Reports.
    3. Under REPORT TITLE, enter a report name.
    4. Under REPORT MODE, select one of the MQTT options: MQTT or ALMS and MQTT.
    5. Under MQTT TOPIC REPORT NAME, enter a report name. In the below image, the report is named avgpi (AirVantage General Purpose Inputs).
    6. Under REPORT CONTENT, select GPIO ARA from the list.
      GPIO ARA consists of the following data points:
      • atp.gpi: GPIO Input Cumulative, which is a binary report of all five GPIO data points:
        • Primary GPIO Input (on power connector) 0th bit: atp.pgpio
        • GPIO Input 2 bit position 1: atp.gpio2
        • GPIO Input 3 bit position 2: atp.gpio3
        • GPIO Input 4 bit position 3: atp.gpio4
        • GPIO Input 5 bit position 4: atp.gpio5
          • Primary GPIO Input: true
          • GPIO Input 2: true
          • GPIO Input 3: false
          • GPIO Input 4: true
          • GPIO Input 5: false
    7. To generate a report on state change of one of the GPIO inputs, go to Unconditional Triggers and turn on ENABLE and select the GPIO report under GENERATE THIS REPORT….
    8. Set the AT EVERY SAMPLE OF… to GPIO Input Cumulative.
    9. Click SAVE.
    10. Under Telemetry > MQTT, configure the connection to your MQTT server.
