| HTTP ACCESS | Configure HTTP AirLink OS WAN access | Enable, Disable, Redirect to HTTPS | Redirect to HTTPS (RECOMMENDED) |
| HTTP PORT | Configure HTTP port for Airlink OS WAN access | 1 to 65535 | 80 |
| HTTPS ACCESS | Configure HTTPS Airlink OS WAN access | Enable/Disable | Enable |
| HTTPS PORT | Configure HTTPS port for Airlink OS WAN access | 1 to 65535 | 443 |
| HTTPS CERTIFICATE | If using HTTPS, select and/or create a security certificate. See Security Certificates Documentation here on how to create a PEM certificate. For HTTPS, only a certificate and private key is required. Certificate, private key and root can be used, but root will be ignored. Root only certificates will not work. | N/A | N/A |
| HSTS | HTTP Strict Transport Security | Off/On | On |
| SESSION IDLE TIMEOUT | The amount of idle time required before the user is automatically logged out and redirected to the login screen. | 1 to 1440 mins | 5 mins |
| MAXIMUM LOGIN ATTEMPTS | The number of failed login attempts allowed before the user account is temporarily locked for the length of time specified in the UNLOCK TIME field. Disabling this feature is not recommended. | 0(disabled) to 5 | 3 |
| UNLOCK TIME | The length of time that the user account is locked after the maximum number of failed login attempts MAXIMUM LOGIN ATTEMPTS. | 1 to 3600 seconds (1 hour) | 120 seconds (2 minutes) |
You can configure any or all of these schemes at the same time. When more than one scheme is configured, the authentication is successful if at least one of the schemes authenticates the user.
Successful authentication can take time. For example, if you have all three authentication schemes enabled, AirLink OS first attempts to reach the LDAP server. If it is unable to reach the LDAP server in the configured timeout period, it abandons the attempt and tries to reach the RADIUS server. If that server is unreachable after the timeout period, it then tries to reach the TACACS+ server. If none of the servers are reachable in the configured timeout periods, AirLink OS falls back to AirLink OS user name and password authentication.
AirLink OS uses LDAP, RADIUS, and TACACS+ to provide user authentication which will grant valid user administration rights to the AirLink router settings. Authorization is not configurable though these tools and therefore care should be taken to ensure that LDAP, RADIUS, and TACACS+ users are authorized to modify the device settings.
| FILE NAME | Required file name | N/A | N/A |
| SERVER | Required LDAP server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 389 |
| TIMEOUT |
| ENCRYPTION | Encryption type. |
start_tls |
| BASE DN | The Base DN is the path in the LDAP tree to the list of users (e.g. dc=sierrawireless,dc=com). This is where the LDAP protocol searches for a matching user to authenticate. | N/A | N/A |
| BIND | Choose how the LDAP search is done |
anonymous |
| BIND DN | This field only appears if you selected Explicit in the BIND field. The full path of the user authorized to perform requests in the LDAP | N/A | N/A |
| BIND PASSWORD | This field only appears if you selected Explicit in the BIND field. Password associated with the Bind DN | N/A | N/A |
| CONFIGURATION FILE NAME | Required configuration file name | N/A | N/A |
| SERVER | Required RADIUS server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 1812 |
| TIMEOUT |
| SECRET | Shared secret for configured server | N/A | N/A |
| SERVER | Required TACACS+ server IP address or resolvable domain name | N/A | N/A |
| PORT | Port number | 1 to 65535 | 49 |
| TIMEOUT |
| AUTHENTICATION PROTOCOL | Shared secret for configured server |
PAP |
| SECRET | The type of bind used for authentication | N/A | N/A |
| LEGAL TEXT INSIDE LOGIN ZONE | This will display the text inside the login zone under the SIGN IN button |
| LEGAL TEXT OUTSIDE LOGIN ZONE | This will display the text outside the login zone |
Example:
