This page shows you how to configure Wi-Fi for your AirLink XR90 router in Access Point mode and Client mode.
When configured as a Wi-Fi Access Point, multiple wireless devices can connect to the router and use the cellular WAN to access the network. The router can also be configured as a Wi-Fi Client where the router can connect to another Wi-Fi network, instead of the cellular WAN.
| WI-FI INTERFACE | MODE | ANTENNA BANK |
| Wi-Fi A 5GHz |
Access Point (Default) |
Always uses Antenna Bank A (i.e. “Wi-Fi A” connectors). |
| Wi-Fi AP 2.4GHz | Access Point (Default) |
Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”) |
| Wi-Fi B 5GHz |
Client (Default) |
Always uses Antenna Bank B (i.e. “Wi-Fi B” connectors). |
| Wi-Fi Client 2.4GHz | Client (Default) | Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”) |
The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System(GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) transmitted by the carrier and directly received by the device’s receiver. The router will automatically load the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and will enable 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it will default to the factory defined setting and disable 802.11d.
Depending on the Region, an OUTDOOR field may optionally be displayed. This allows you to restrict the available channels according to Wi-Fi region regulations. The default is Disabled, indicating an Indoor configuration, which will follow standard regulatory compliance requirements. Outdoor deployments may have additional regulatory considerations, especially if they operate in certain frequency bands. This option will be removed in AirLink OS Release 5.1.
In the Physical field, select the network standard to use.
In the Channel Bandwidth field, select the bandwidth to use (up to 80 MHz). Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz).
Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality. Each Wi-Fi antenna bank can have up to 4 antennas connected. Select a non-default setting for an access point if you discovered problems with legacy equipment, have fewer than the maximum number of antennas connected, or to improve the XR90’s thermal performance.
DFS Channels is always enabled for 5GHz radios that have the MODE set to Client.
Best Practice recommendation: If the 2.4GHz and 5GHz AP(s) are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP adresses when switching between the APs.
For all security modes except OPEN, enter a SECURITY PASSPHRASE of at least 8 characters.
For WPA2 and WPA2-Enterprise security modes only, select the 802.11W option.
Note: The 802.11w options do not appear for WPA3 or WPA2/WPA3 Transition Mode. For WPA2/WPA3 Transition Mode, ‘Optional’ is automatically used. For WPA3, “Required’ is automatically used.
Enable AUTO CHANNEL to have the router choose the channel on which to operate.
Enable AUTO BEACON INTERVAL to have the router send periodic messages (beacons) to advertise its availability. To choose a specific interval, disable AUTO BEACON INTERVAL and then manually enter the required BEACON INTERVAL in milliseconds (100 ms is the default).
Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect.
- Wi-Fi A 5GHz in AP mode supports up to 128 clients (includes clients connected to up to two additional 5GHz SSIDs)
- Wi-Fi AP 2.4GHz supports up to 64 clients (includes clients connected to up to two additional 2.4GHz SSIDs)
- Wi-Fi B 5GHz in AP mode supports 64 clients (includes clients connected to up to two additional 5GHz SSIDs)
For example (using the Wi-Fi A 5GHz radio in the figure below, which is capable of supporting up to 128 clients):
Configured Maximum Total Allowed Wi-Fi A 5GHz connected Wi-Fi A 5GHz SSID 1 connected Wi-Fi A 5GHz SSID 2 connected Available Wi-Fi A 5GHz = 128
Wi-Fi A 5GHz SSID 1 = 128
Wi-Fi A 5GHz SSID 2 = 128128 50 46 0 32 across all three SSIDs Wi-Fi A 5GHz = 30
Wi-Fi A 5GHz SSID 1 = 20
Wi-Fi A 5GHz SSID 2 = 1060 25 20 5 10 across Wi-Fi A 5GHz and Wi-Fi A 5GHz SSID 2
(Wi-Fi 5GHz A SSID 1 is at max.)
Up to two additional SSIDs can be enabled for each of the access point interfaces (i.e., two for Wi-Fi A 5GHz, two for Wi-Fi AP 2.4GHz, and two for Wi-Fi B 5GHz).
A DUAL-BAND CLIENT CONNECTION is a network configuration where the router can connect to a Wi-Fi network using either the 2.4GHz frequency band or the 5GHz frequency band. This allows the router to choose between these two frequency bands based on various factors such as signal strength and network congestion. When DUAL-BAND CLIENT CONNECTION is enabled, it is capable of switching dynamically between these frequency bands, which is useful in environments with multiple Wi-Fi networks and varying levels of interference.
Only one band will be connected at any time. The underlying interfaces will share a single MAC address. Roaming between bands will take place according to internal thresholds, with a preference for the 5GHz band. Roaming within the band will function as usual.
Tip: It is recommended that the BACKGROUND SCAN INTERVAL, configured in the Wi-Fi Interface, is set to 30s, in order to have the best roaming experience.
Note: The SSID Priority setting is not supported across the bands, but it is supported within the band.
If both 2.4GHz and 5GHz Wi-Fi interfaces with distinct MAC addresses are activated, the DUAL-BAND CLIENT CONNECTION field can be configured.
When DUAL-BAND CLIENT CONNECTION is set to On, then the following fields will appear:
To configure this feature:
To use a scanned SSID:
To create an SSID manually:
Note: For WPA2/WPA3 Transition mode access points, Optional is used automatically. For WPA3-only access points, Required is used automatically.
