    Enabling ALMS Advanced Mobility Reporting
    The AirLink XR Series routers, with their vehicle telemetry capability and inertial sensors, will support all features of AMR.
    As well, ensure that the ignition SHUTDOWN DELAY is set to at least 30 seconds (the default setting is 3 seconds).
    1. Under Services > Location > General, ensure that GNSS is enabled.
    2. Under Services > Telemetry > General, enable SERVICE.
    3. Under Services > Telemetry > Vehicle:
      • Enable DATA COLLECTION.
      • Set MODE OF OPERATION to Active when Ignition is ON.
      • Set VEHICLE IGNITION WIRING to Connected AirLink gateway Ignition Sense input line.
    4. Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
      • In the POWER SOURCES table, click Edit ( ) on the row for Source > Ignition.
      • Set the SHUTDOWN DELAY to at least 30 seconds.
      • Click UPDATE.
