    Reboot and Reset
    1. Locally by accessing the AirlinkOS UI with a PC connected on the router’s LAN
    2. Physically by pressing the reset button on the router
    3. Remotely via ALMS
    Reboot
    Reset
    • reset using factory defaults
    • reset using a custom template
    • DEVICE RESET BUTTON: Enables the Reset button on the router.
    HOLD BUTTON FOR ... ACTION POWER LED BEHAVIOR
    < 5 seconds Release to reboot the router Fast flashing green
    5 to 20 seconds Release to reset to the RESET CONFIGURATION TYPE state Fast flashing red
    20 to 40 seconds Release to reset to factory defaults Fast flashing yellow
    Over 40 seconds Release to cancel reset Fast flashing yellow and red
    • RESET CONFIGURATION TYPE: This setting is used to specify what type of reset configuration will be used when resetting the router configuration.
      • USE FACTORY DEFAULTS will reset the router to factory default configuration.
      • USE CUSTOM TEMPLATE allows you to specify a custom template as your default configuration, when the router is reset. Select USE CUSTOM TEMPLATE and it will display the current template that is stored. If the CURRENT TEMPLATE is blank or you wish to change the custom template used, then click SET TEMPLATE to load the template from your local computer.
    • Click RESET SETTINGS to reset the router. A confirmation screen will appear.
    • Click CANCEL to cancel the reset, or click RESET SETTINGS to reset.
