The Friendly Name for WAN Monitors can be changed via a configuration template.
The best practice is to create a separate configuration template that only contains the Friendly Name change for any Monitors.
1. To rename a rule, first create a template from scratch. See Creating a Configuration Template from Scratch
2. Select the building block, WAN Monitor Specification.
3. Use the + button on the ICMP ping monitors
to add a Monitor entry
4. For each entry, enable the Rename this entry on gateway
5. Enter the current Friendly Name
that you wish to change.
6. Then enter the New Name
7. Repeat from step 3 for each monitor that you wish to rename.
8. The template is now ready to be published and deployed.
