2. Select the Network and Serial Devices building block.
3. Use the + button on the Network Devices
to add a Network Device.
4. The Rename this entry on gateway option
provides a convenient method for renaming an existing device on target gateways via the template.
5. When enabled, the Device Location drop down menu field
and a New Name field
will appear. This will allow you to specify which device that you want to rename and also what the new name will be.
Note: The Device Location can be determined from the LCI of the device under the Devices tab.
If you do not wish to rename a device, then ensure that the Rename this entry on gateway option
is unchecked and that the Friendly Name option
matches the configuration of the device. Then only the Device Use field
is configurable.
Note: In the Device Use field, the LAN option is only applicable to Ethernet and WiFi. The WAN option is applicable to all network devices.
6. Repeat from step 3 for each device that you wish to rename.
7. The template is now ready to be published and deployed.
