The Friendly Name for user defined VPNs can be changed via a configuration template.
Note: The management tunnel vpn name and user name should never be changed as this is required by the AMM.
The best practice is to create a separate configuration template that only contains the Friendly Name change for any VPNs.
1. To rename a rule, first create a template from scratch. See Creating a Configuration Template from Scratch
2. Select the building block, VPN Specification.
3. Use the + button on the VPN Profiles
to add a VPN entry.
4. Enable the Type
5. Change the Type to IPSEC.
6. Enable the Rename this entry on gateway
7. Enter the current Friendly Name
that you wish to change.
8. Then enter the New Name
9. Repeat from step 3 for each VPN that you wish to rename.
10. The template is now ready to be published and deployed.
