The Friendly Name for user defined WIFI Networks can be changed via a configuration template.
The best practice is to create a separate configuration template that only contains the Friendly Name change for any WiFi Networks.
1. To rename a rule, first create a template from scratch. See Creating a Configuration Template from Scratch
2. Select the building block, WiFi Networks Specification.
3. Use the + button on the WiFi Networks
to add a WiFi Network entry.
4. For each entry, enable the Rename this entry on gateway
5. Enter the current Friendly Name
that you wish to change.
6. Then enter the New Name
7. Repeat from step 3 for each WiFi Network that you wish to rename.
8. The template is now ready to be published and deployed.
