To maintain consistency across your fleet, it is recommended that the gateways use the same version of firmware and application.
The general process to upgrade firmware on a fleet is as follows:
For AMM 2.18.1 and later, as an administrator user, login to the AMM and go to Admin > Software > Repository
Select Check Now and search for AOS-Core-Software and aos-delsadapter. Refer to Release Notes for the currently suported releases. If you do not see the currently supported releases, please contact Technical Support.
Select the AOS-Core-Software and aos-delsadapter and then click Download.
When it is finished, the status will change to Available.
More information about the repository screen can be found at Software Repository .
Once the software images are uploaded into the AMM, it is now possible to upgrade the firmware on the AirLink OS routers.
NOTE: For AMM 2.18 and later, the only supported application is aos-delsadapter. There is no support for other third party applications. A third party application can still be installed on the AirLink OS router by using an external docker registry, however it will not be managed by AMM.
NOTE: It is highly recommended that a fleet is upgraded in stages, that allow sufficient time between stages to field test the change.
Note: If more than one type of gateway is selected, the Upgrade Gateway Software wizard will ask you to specify which platform you want to upgrade.
Note: For AirLink OS firmware, the software is labeled as AOS-Core-Software.
Note: All updates are scheduled according to Pacific time, either PST or PDT.
Note: There is no operation created for application install/upgrades.
More information about the distribution screen can be found at Software Distribution .
