WP8548 & WP75xx Firmware Release 16.1/17 Components
- Sep 11, 2023
- Version: 16.1/17
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.1/17 components and how to download it on your product.
WP8548 & WP75xx Firmware Release 16.1/17 combined image
| Modem Firmware (Generic — GCF/PTCRB) |
SWI9X15Y_07.13.07.00 / 001.040_000 |
| Modem Firmware (Generic — Anatel) |
SWI9X15Y_07.14.01.00 / 001.042_000 |
| Modem Firmware (AT&T) |
SWI9X15Y_07.13.07.00 / 001.036_000 |
| Modem Firmware (Sprint) |
SWI9X15Y_07.13.07.00 / 001.027_000 |
002.004 |
SWI9X15Y_07.13.05.00 |
| SWI9X15Y_07.14.01.00 |
18.06.4 |
| 18.06.4 Source |
Release 16.1: SWI9X15Y_07.13.05.00 Source (Based on Kernel 3.14 and Yocto 2.2) |
Open Source Licenses | Release 16.1: 32-bit ToolChain 64-bit ToolChain |
| Release 17: SWI9X15Y_07.14.01.00 Source (Based on Kernel 3.14 and Yocto 2.2) |
Release 17: 32-bit ToolChain 64-bit ToolChain |
