WP8548 & WP75xx Firmware Release 15 Components
  • Jan 11, 2018
  • Version: 15
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15 components and how to download it on your product.
WP8548 & WP75xx Firmware Release 15 combined image
SWI9X15Y_07.12.14.00 / 001.034_000
SWI9X15Y_07.12.09.00 / 001.033_000
Modem Firmware (AT&T)
SWI9X15Y_07.12.09.00 / 001.028_000
Modem Firmware (Sprint)
SWI9X15Y_07.12.09.00 / 001.020_000
002.004
16.10.4
16.10.4 Source
SWI9X15Y_07.12.14.00 Source
(Based on Kernel 3.18 and Yocto 1.7)
    • MCU Firmware: mcuFW.cwe
