WP8548 & WP75xx Firmware Release 16 Components
- Sep 28, 2018
- Version: 16
WP8548 & WP75xx Firmware Release 16 combined image
SWI9X15Y_07.13.07.00 / 001.040_000 |
002.004 |
SWI9X15Y_07.13.05.00 |
18.06.1 |
| 18.06.1 Source |
SWI9X15Y_07.13.05.00 Source (Based on Kernel 3.14 and Yocto 2.2) |
