Solid Green
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Off
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
A yellow LED chase pattern indicates an AirLink OS software update in progress.
