    Configuring Wi-Fi
    This page shows you how to configure Wi-Fi for your AirLink RX55 router in Access Point mode and Client mode.
    Wi-Fi Interfaces
    • Wi-Fi A
    • Wi-Fi B
    Each interface is configurable as Access Point (2.4GHZ or 5GHz) or Client (2.4GHz, 5GHz, or 2.4GHz + 5GHz).
    For example:
    • The router will provide a Wi-Fi Access Point (using the cellular WAN) in the vehicle for laptops and other client devices.
    • The router will also provide a Client mode interface for when the vehicle enters a depot, where the router can connect to another Wi-Fi network (instead of the cellular WAN). The in-vehicle devices can then take advantage of the Wi-Fi WAN network (for example, to upload video camera or vehicle data to the depot network.)
    To configure an interface as an Access Point, click at the end of a row for Wi-Fi A or Wi-Fi B in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface.
    • Select the MODE — Access Point in this case.
      Best Practice recommendation: If 2.4GHz and 5GHz APs are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP adresses when switching between the APs.
      • WPA — This option appears only when LEGACY MODE is enabled. Requires only a SECURITY PASSPHRASE. (This mode is not recommended.)
      • WPA2-Enterprise — Requires operation; clients that do not support 802.11w will not connect.
      Note: The 802.11w options do not appear for WPA3 or WPA2/WPA3 Transition Mode. For WPA2/WPA3 Transition Mode, ‘Optional’ is automatically used. For WPA3, ‘Required’ is automatically used.
      • Select the RADIUS AUTHENTICATION SERVER to use.
      • Select the RADIUS ACCOUNTING SERVER to use. Note: RADIUS servers must use IPv4 addresses. FQDNs and IPv6 addresses are not supported.
    • Set LEGACY MODE — When enabled, Legacy Mode restores security option WPA (version 1) in the SECURITY MODE list, and supports TKIP encryption for WPA/WPA2 modes. When disabled, only AES encryption is supported.
      • For passenger Wi-Fi applications, enable client isolation to enhance security.
      • Disable client isolation if you have client applications on the same LAN segment that need to interact with each other.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect. The default is 10, with a range of 1 to 10.
      • Disabled (default)
    A DISABLE APS ON CLIENT ASSOCIATION switch is below the WI-FI INTERFACES table.
    To configure this feature:
    Configuring Wi-Fi Client Mode
    Tip: Rest the pointer on an SSID to view the channel, BSSID and RSSI for each band.
    To use a scanned SSID:
    4. Click UPDATE.
    To create an SSID manually:
    3. Select a SECURITY MODE. For mode WPA2 or WPA2 Enterprise, 802.11w options appear. If required, select an option to enable 802.11w operation. The 802.11w standard uses Security Association Query Requests to ensure that clients are legitimate. Options are:
      • Disabled
      • Required: forces 802.11w operation; the router will not connect to access points unless they have 802.11w enabled. For WPA2/WPA3 Transition mode access points, Optional is used automatically. For WPA3-only access points, Required is used automatically.
    4. Select the PRIORITY. The smaller the value, the higher the priority. Leaving PRIORITY blank puts this SSID at the lowest priority.
    5. Click CREATE.
    • Leave the MODE as Client.
