    Stats Reported for MGOS Devices
    This section lists some of the commonly used stats that can be reported by MGOS devices. The MGOS devices may not report stats with every communication, and stats related to hardware that is not supported by a device will not be reported.
    • BootReason: the reason why the device was booted up. In normal operation, this would always be “Ignition”.
    • CallUp: indicates if there is an active link up.
    • CMOSBattery: voltage currently reported by the CMOS battery.
    • ConfigSyncedStatus: status of configuration synchronization between AMM and device. Indicates whether the gateway and the server copies of the configuration files are the same or not.
    • ConfigTemplate: latest template applied.
    • ConfigTemplateChange: date/time of when latest template was applied.
    • ConfigTemplateInSync: status of latest template applied between AMM and device.
    • ConfigurationState: the configuration sync status of the gateway.
    • CPU-load-10: average CPU load for last 10 seconds.
    • CPU-load-60: average CPU load for last 60 seconds.
    • CPU-load-300: average CPU load for last 300 seconds.
    • FIPS: indicates if the device software has the FIPS-compliant build or not.
    • Ignition: if the ignition is on or not.
    • MainBattery: voltage being reported at the input terminal of the MGOS device.
    • Platform: the type of platform (e.g. MG, GX400, RV50, etc.).
    • ReportIdleTime: represents the device’s heartbeat.
    • ShutdownReason: reason for MGOS device shutdown.
    • SoftwareVersion: the version of the device’s software.
    • Temperature: the internal ambient temperature in the device.
    • UpTime: the amount of time that the device has been booted up.
    Communication Stats
    Note: There are multiple ethernet ports on an MGOS device. # will indicate the number of the port. These will be present only if an ethernet port has ever been used as a WAN link, such as for bench work or connected to an external uplink device such as a satellite communication controller.
    • Ethernet#-Active: indicates if the ethernet is currently the active WAN link or not.
    • Ethernet#-CallUpTime: the time that the ethernet has been connected as an active default route.
    • Ethernet#-IPAddress: the ip address that the ethernet has.
    • Ethernet#-TotalrxBytes: total number of received bytes since boot up.
    • Ethernet#-TotaltxBytes: total number of transmitted bytes since boot up.
    • Ethernet#-txBytes: total number of transmitted bytes for the current call.
    • Ethernet#-txRate: total number of received bytes for the current call.
    Note: The stats below are repeated for each possible WAN interface configured in the system, identified by the mount point of the device. Cell A and Cell B are respectively MiniUSBSS3 and MiniUSBSS4 for an MG90 device. MiniUSBS3 and MiniUSBS4 are used on oMG-2000 and oMG-500. LinkX indicates the current active WAN interface and provides the same data for whichever is the current default route.
    • [LinkLocation]-Active: indicates whether the current default route is accessbile.
    • [LinkLocation]-CallUpTime: length of time that the current data call has been in place.
    • [LinkLocation]-IPAddress: the ip address of the link.
    • [LinkLocation]-RSRP: the average power received from a single reference signal. Typical range is around -44dbm(good) to -140dbm(bad). Applies to 3G and 4G LTE only.
    • [LinkLocation]-RSRQ: indicates quality of the received signal. Typical range is around -19.5db(bad) to -3db(good). Applies to 3G and 4G LTE only.
    • [LinkLocation]-SINR: signal to noise ratio of the given signal. Applies to 3G and 4G LTE only.
    • [LinkLocation]-RSSI: represents the entire received power present in the received signal. Applies to 3G and 4G LTE only.
    • [LinkLocation]-5G RSRP: the average power received from a single reference signal. Typical range is around -44dbm(good) to -140dbm(bad). Applies to 5G only.
    • [LinkLocation]-5G RSRQ: indicates quality of the received signal. Typical range is around -19.5db(bad) to -3db(good). Applies to 5G only.
    • [LinkLocation]-5G SINR: signal to noise ratio of the given signal. Applies to 5G only.
    • [LinkLocation]-rxBytes: total number of received bytes for the current data call.
    • [LinkLocation]-TotalrxBytes: total number of received bytes in a 24-hr period, resetting at GMT daily.
    • [LinkLocation]-TotaltxBytes:total number of transmitted bytes in a 24-hr period, resetting at GMT daily.
    • [LinkLocation]-txBytes: total number of transmitted bytes for the current data call.
    • [LinkLocation]-Up: if the current active link is connected.
    • [LinkLocation]-WANClassification: information about the current active WAN link, such as cellular carrier, IMSI, IMEI, ICCID (SIM ID).
    • [LinkLocation]-WANSignalStrength: signal strength as calculated by the configuation in the cellular wan link; by default a rolling average of the last 10 samples. The number of samples used and the threshold required for the device to report a new value are configurable in the WAN link configuration.
    • [LinkLocation]-WANSNR: WAN Signal to Noise Ratio.
      Note: The following SSC (secondary serving cell) stats are carrier aggregation information. The SSC can have values from 1 to 4.
    • [LinkLocation]-SSC(#)-State: Possible values are Active/Inactive/Not assigned.
    • [LinkLocation]-SSC(#)-BandNum: e.g. value n66.
    • [LinkLocation]-SSC(#)-BW: e.g. value 20.
    • [LinkLocation]-SSC(#)-Channel: e.g. value 5145.
    VPN Stats
    • IPsecVPNTunnel: if the VPN tunnel is up or not.
    • IPsecVPNTunnelUpTime: how long the VPN tunnel has been up for.
    • VPNIndividualTunnelDownTime: how long an individual tunnel has been down.
    • VPNIndividualTunnelState: the state of an individual tunnel.
    • VPNIndividualTunnelUpTime: how long an individual tunnel has been up.
    GPS Stats
    • GPS AntennaStatus: the status of the GPS antenna. Possible values are OK, Unknown, Open circuit, Short circuit.
    • GPS Location-altitude / GPS Location-latitude / GPS Location-longitude: the device’s current GPS coordinates at time of reporting.
    • GPS Location-miles: the miles traveled on a given day.
    • GPS Location-speedmph: the speed, in miles per hour at the time of the reporting.
    • GPS Location-zone: the zone in which the gateway traveled. See Zones for more information. This stat is calculated by the server based on existing Zones and the device’s coordinates at a given time.
    • GPS Satellites: the number of satellites that are in view. Not useful for location troubleshooting since it is based on archival data and anticipated location.
    • GPS Satellites In Use: indicates whether there are sufficient satellites currently in use to support a particular fix-dimension (2 or 3).
    • GPSFix: the time since the last 2D or 3D GPS fix.
    Asset Tag Stats
    If you have purchased asset tags, the following lists some of the commonly used stats.
    • AssetBattery: the voltage of the battery on the asset tag.
    • AssetSignal: the signal strength of the asset tag.
    • AssetState: the state of the asset tag.
    • AssetTemperature: the temperature being recorded by the asset tag.
    Telemetry Stats
    If you are using telemetry, the following lists some of the most commonly used stats. For more information about telemetry, see Telemetry Tab.
    • AmbientAirTemperature: ambient air temperature reported by the ECU sensor.
    • BarometricPressure: barometric pressure as reported by the ECU sensor.
    • Battery: vehicle battery voltage as reported by the OBD-II connection.
    • CatalystTemperature1-1: reported temperature of the catalytic converter sensor.
    • DiagnosticTroubleCode: diagnostic trouble code.
    • DistanceSinceCodesReset: the distance travelled since the last DTCs were cleared by a scan tool.
    • DistanceSinceMILOn: distance since the last time the MIL was on.
    • EngineCoolantTemperature: temperature of the coolant system as reported by the ECU sensor.
    • EngineRPM: current engine RPM as reported by the ECU sensor.
    • FuelLevelInput: shown as a percentage of the tank.
    • IntakeAirTemperature: temperature of the air intake as reported by the ECU sensor
    • MilOn: check engine light status (Malfunction Indicator Lamp).
    • OBDScannerConnected: indicates if the scanner is currently connected (a value of 1) or is disconnected (a value of 0).
    • Odometer: shows odometer reading of the vehicle. Note: This parameter is dependent on the Distance since codes cleared (DSCC) PID. If “DSCC” is not available on the vehicle, then this parameter will not be reported.
    • TimeAtIdle: the amount of time spent idling.
    • TimeSinceCodesCleared: length of time since the most recent trouble codes were cleared.
    • TimeSinceEngineStart: length of time since the engine was last started.
    • TimeSinceMilOn: length of time since the last time the MIL was on.
    • VehicleSpeed: the last recorded velocity of the vehicle. Measured in kilometers per hour.
    • VIN: vehicle Identification Number. Unique 17 digit serial number assigned to the vehicle by the manufacturer.
    Stat FAQs
    • What does “LinkX-ActiveLink” mean?
      “LinkX-ActiveLink” is the active WAN link that AMM is tracking.
    • What is the purpose of LinkX?
      LinkX allows a threshold to be set on the WAN active link, irrespective of whether it is on WiFi or potentially on different cell links.
