    Supported Gateways
    AMM works with the following gateway versions. Note that some specific features may require newer/specific versions which are noted in this document.
    • oMG 3.14.1 and above1.
    • MG90 4.0.2 and above.
    • AirLink devices2 with ALEOS software versions 4.4.x and higher. ALEOS devices with versions lower than 4.9.4 will require a manual configuration change in order to communicate with the AMM 2.17.1+. Many of the reports enabled for ALEOS devices in AMM 2.16+ require ALEOS 4.8.0 and the AMMER AAF application.
    Note: the AMM generally handles all MG devices in a similar manner. Where appropriate, all references to “MG” in this document refer collectively to oMG 500, 2000, and MG90 devices, with following exceptions:
    Note: AMM 2.17.1+ supports communication with devices using TLS 1.2. The minimum compatible gateway software versions are
    • oMG-2000: 3.15.0-20180206.2
    • MG90: 4.2.0-20180608.1
    1. All MG devices must be upgraded to 3.14.1 or later prior to upgrading to AMM 2.15+. [return]
    2. Newly released AirLink devices may require later versions of ALEOS, AMMER, and/or AMM software. [return]
