    Configuring Wi-Fi
    This page shows examples from AirLink RX400 and AirLink EX400 routers. Both products have the same Wi-Fi features and functionality.
    Wi-Fi Interfaces
    The router has one Wi-Fi interface, which you can set to operate as:
    • Access Point (2.4GHz or 5GHz)
    • Client (2.4GHz, 5GHz, or 2.4GHz + 5GHz)
    REGION
    The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies and transmit power levels for that regulatory region in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses only channels that are available globally. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink RX400-EX400 Hardware User Guide .
    PLACEMENT
    • When Indoor is selected, the router can use channels allowed for indoor and outdoor use.
    For more information on supported channels, refer to the Wi-Fi specifications in the AirLink RX400-EX400 Hardware User Guide .
    NOTES:
    • Enabling DFS Channels will make DFS-specific channels available in AP mode regardless of the region and, if applicable, PLACEMENT option. DFS (Dynamic Frequency Selection) channels are always enabled when Wi-Fi is in Client mode.
    For details on how your router is determining its region, go to Status > Services > Geolocation.
    To configure an interface as an Access Point, click at the end of the row in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface.
    • Set the MODE to Access Point.
      • WPA — Available when LEGACY MODE is enabled. Requires only a SECURITY PASSPHRASE (This mode is not recommended.)
      • WPA2 — Requires a SECURITY PASSPHRASE and 802.11w options.
    • Enable DFS Channels to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS Channels enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your other operating equipment is DFS capable, Semtech recommends leaving DFS Channels disabled.
      • Enabling DFS allows for more 5GHz channels, but may result in delayed connectivity at boot and in the presence of radar.
      • If the router Access Point (AP) switches channels because of radar activity, the AP does not broadcast for about 30 minutes. In addition, Semtech recommends against configuring the AP interface during that time, otherwise the AP will not resume broadcasting until the router is restarted.
    • For WPA2 and WPA2/WPA3 Transition Mode only, select the 802.11W option.
      • Disabled — for WPA2 mode only.
    • When BAND is set to 5GHz, select the CHANNEL BANDWIDTH to use. Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz). The options are:
      • 20 MHz, 40 MHz, 80 MHz (default)
    • Set the BEACON INTERVAL to configure how often the router sends periodic messages (beacons) to advertise its availability.
      • Range is 50–4000 milliseconds (default is 100)
      • Range is 1–255 (default is 2)
    • Enable HIDE SSID to have the router hide the Access Point SSID from nearby devices scanning for available Wi-Fi networks. For a client to connect to the hidden SSID, the SSID and passphrase must be entered on the client.
      • For passenger Wi-Fi applications, enable Client Isolation to enhance security.
      • Disable Client Isolation if you have client applications on the same LAN segment that need to interact with each other.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to all access point interfaces. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect.
      • Range is 1–16 (default is 16)
      • Disabled (default)
      • Auto — When set to Auto, the MSS is calculated based on the detected MTU (Maximum Transmission Unit) of the network path as discovered by Path MTU Discovery (PMTUD).
    On Status > System > Dashboard, the LAN dashboard shows you the Wi-Fi LAN interfaces and the LAN segments they use. A blue Access Point icon ( ) indicates the interface is enabled and operating.
    Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Access Point status, including the active channel and connected stations (clients).
    Configuring Wi-Fi Client Mode
    You can create a Client Mode configuration by using a scanned SSID from the Client SSID Database, or by creating an SSID. The router will use the SSID for its WAN connection.
    For more information, see this Semtech Customer Community article.
    Tips:
    • Click > or at the top of the page to view the Client SSID Database
    • Click SCAN NOW to refresh the SCANNED SSIDS table.
    • Rest the pointer on an SSID to view the channel, BSSID and RSSI for each band.
    To use a scanned SSID:
    3. In Edit SSID, add the security passphrase and assign a priority (optional).
    4. Click UPDATE.
    To create an SSID manually:
    2. In Create SSID, enter the SSID name.
      • WPA2 — Requires a SECURITY PASSPHRASE, plus **802.11w** options.
      • WPA2/WPA3 Transition Mode — Requires a SECURITY PASSPHRASE, plus **802.11w** options.
      • WPA3-Enterprise — Requires RADIUS Authentication & Acceptance server details
      • WPA3-Enterprise Suite-B (192 Bit) — Requires RADIUS Authentication & Acceptance server details
    4. For all security modes except OPEN, WPA2-Enterprise, WPA3-Enterprise and WPA3-Enterprise Suite-B (192 Bit), enter a SECURITY PASSPHRASE of at least 8 characters.
          • USER PASSWORD
            SETTING DESCRIPTION
            TYPE Root Certificate
            SETTING DESCRIPTION
            TYPE Certificate
    1. For WPA2 and WPA2/WPA3 Transition Mode, select the 802.11w. The 802.11w standard uses Security Association Query Requests to ensure that clients are legitimate. Options are:
    2. Select the BAND — 5GHz, 2.4GHz, or 2.4GHz + 5GHz
    3. Enter the PRIORITY. Priority of networks ordered from 1 (high priority) to 65535 (low priority).
    4. For WPA2-Enterprise, WPA3-Enterprise and WPA3-Enterprise Suite-B (192 Bit) modes, enter the IDENTITY or username as defined on the RADIUS server
    5. Select CREATE.
    To complete or edit the Client mode configuration, click at the end of the row of a Client interface.
    In Edit Wi-Fi Interface, configure the fields in any order.
    • Leave MODE set to Client.
    • Set the SSID SELECTION switch.
      When you have multiple SSIDs configured, Semtech recommends leaving SSID SELECTION at the default Auto (Highest Priority) setting. The router will automatically search and connect to an SSID depending on priority. If priorities are identical, the router will use the closest SSID with the fastest estimated link speed.
    To configure the Wi-Fi client to use only a single, specific SSID, set SSID SELECTION to “Manual” and then choose the CONFIGURED SSID to which the router will connect.
    • DFS CHANNELS is enabled when BAND is set to 5GHz or 2.4GHz + 5GHz. This non-configurable setting opens up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS CHANNELS enabled, the router will switch channels if it detects radar equipment using the same channel.
      • 20 MHz, 40 MHz, 80 MHz (default).
    • Enter the SCAN INTERVAL, which sets how often the router scans for SSIDs when disconnected. The options are:
      • 5–65535 seconds (default is 5)
    On Status > Dashboard, the WAN and LAN dashboards show you the Wi-Fi interfaces. A grey Wi-Fi icon ( ) indicates a disconnected interface. A blue Wi-Fi icon ( ) indicates a connected interface.
    Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Client or Access Point status.
    Some Wi-Fi security modes with specific configuration settings are equivalent to other modes, which may cause overlap between Access Point and Client security modes. In some situations, the router client may report the security mode selected by the Access Point (some WPA2-Enterprise modes can appear as WPA3-Enterprise, for example), which may not be expected considering the router’s configured security mode.
