Telemetry data collection requires the router to be properly installed and connected to the vehicle. For most applications, you must connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the RX400-EX400 Hardware User Guide.
To view the status of your telemetry configuration, go to Status > Services > Telemetry.
J1939 and J1979 protocols are currently supported. Semtech is investigating support for J1979-2 and J1979-3 and VDV 238 protocols. AirLink OS can currently detect both J1979 and J1979-2, but as shown below, Telemetry status will indicate whether a protocol version is not supported.
Define reports with your specific data requirements that can be sent to an MQTT broker.
| REPORT MODE | Destination of where reports will be sent to. The MQTT configuration will only display when the REPORT MODE is set to the MQTT option. |
Report that will be generated when the device powers off. Note: Only one report can be selected, and in situations where there is an abrupt power disconnect a report may not be generated. |
| AT EVERY SAMPLE OF… |
Example 2: WAN Ready
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are:
Options are:
Options are:
N/A | N/A |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 |
ATP FORMAT |
Individual Timestamp |
| CONNECTION SECURITY |
None |
| ROOT CERTIFICATE |
N/A |
