Solid Green
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Off
BARS | GSM/2G | WCDMA/3G | LTE/4G and 5G | |
RSSI | RSSI | RRSP | SNR | |
5 | x ≥ -78 | x ≥ -76 | x ≥ -85 | x ≥ 130 |
4 | -78 > x ≥ -87 | -76 > x ≥ -83 | -85 > x ≥ -95 | 130 > x ≥ 50 |
3 | -87 > x ≥ -93 | -83 > x ≥ -93 | -95 > x ≥ -105 | 50 > x ≥ 10 |
2 | -93 > x ≥ -102 | -93 > x ≥ -103 | -105 > x ≥ -115 | 10 > x ≥ -30 |
1 | -102 > x ≥ -109 | -103 > x ≥ -113 | -115 > x ≥ -1000 | -30 > x ≥ -200 |
0 | x < -109 | x < -113 | x < -1000 | x < -200 |
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
A yellow LED chase pattern indicates an AirLink OS software update in progress.
