In the above example,
When NETWORK OPERATOR SWITCHING setting is set to Manual, you can manually switch the radio module firmware to a specific network operator using this process. You can check the NETWORK OPERATOR SWITCHING setting in the Hardware Interfaces > Cellular Interfaces > Cellular section.
Power the router on.
Go to Hardware Interfaces > Cellular Interfaces.
Under Cellular > NETWORK OPERATOR SWITCHING, click Automatic to switch it to Manual.
Under SELECT NETWORK OPERATOR, select your desired carrier.
Click SAVE.
The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take about 2-5 minutes depending on the RMFW version it is updating to.
