You can configure the router as a VPN client or VPN server. The table below outlines how the router operates in each mode.
SERVER MODE | CLIENT MODE | |
Overall relationship | Master – sets all details for connection, for all clients. AirLink routers running AirLink OS can support multiple clients connected simultaneously and are limited only by the throughput requirements of those clients. | Slave – must match the defined details for a single connection as defined on the target server |
Tunnel specifications | Server defines/sets the configuration: authentication mechanism and details, network details | Client must match a configuration set on the server to which it is connecting |
Network communication | Server defines what “enterprise” or central network(s) are available to remote clients, and what the expected remote network connection will look like (LAN or Host termination) | Client provides the remote network segment in LAN termination and may provide the individual host address for Host termination if the server does not have the ability to assign one |
Routing | Server advertises routing information to the central network to access remote clients | Client provides routing for remote clients to access the central network |
Connection details | Accepts or rejects tunnel connection requests | Requests a tunnel connection |
These are the settings you’ll find in the Basic Configuration Steps described below. For Host-terminated applications, you must configure the virtual IP settings that control how the router acquires a virtual IP address (either automatically from the VPN server, or manually).
SETTING | DESCRIPTION | DEFAULT SETTING | RANGE |
NAME | Descriptive name for the tunnel | n/a | n/a |
MODE |
Client | Client, Server |
LAN/HOST MODE |
LAN | LAN, HOST |
USE DEFAULT VIRTUAL IP POOL(S) | Appears when the tunnel is being configured for Server/HOST mode. | Enabled | Enabled, Disabled |
VIRTUAL IP ADDRESS POOL(S) |
CLIENT VIRTUAL IP TYPE |
Appears when the tunnel is being configured for Client/HOST mode. Selects how the virtual IP address is assigned. In most applications, Sierra Wireless recommends leaving this setting at Automatic, and the virtual IP address will come from the server’s configuration. If set to Static, the entered VIRTUAL IP ADDRESS (see below) will be used without requesting confirmation from the Server. |
Automatic | Automatic (requests a virtual IP address from the server), Static |
VIRTUAL IP ADDRESS |
n/a | n/a |
RANK |
When multiple IPsec tunnels are configured and the CONNECTION METHOD is set to Prioritized, the RANK determines the tunnel’s failover priority (1 being the highest rank; 100 the lowest). The highest-ranking established tunnel (as determined by the VPN Link Monitor) will be the active IPsec tunnel. An active IPsec tunnel will fail over to a lower-ranking tunnel if the active tunnel fails. You can also set the RANK in the TUNNELS table when the CONNECTION METHOD is set to Prioritized. |
1 | 1–100 |
IKE VERSION | Sets the Internet Key Exchange (IKE) mode. The default setting of IKEv2 is required for FIPS mode and MOBIKE. You may need to select IKEv1 when the router is in Client mode and a third-party VPN appliance is not compatible with IKEv2. | IKEv2 | IKEv2, IKEv1 |
MULTIPLE SA’s FOR IKEV2 | Enables compatibility with Cisco VPNs when multiple remote subnets are used in a single child SA. If you define multiple remote subnets under REMOTE SUBNETS, enable this setting to create a separate child SA for each remote subnet. | Disabled | Disabled, Enabled |
MOBIKE |
AUTHENTICATION TYPE | Sets the authentication type/method | Certificate | Certificate, PSK |
CERTIFICATES |
When AUTHENTICATION TYPE is Certificate, lets you add or create/upload PEM certificates for authentication. ![]() |
n/a | n/a |
PSK |
n/a | n/a |
PEERS | Required to identify the peer side of a VPN connection. This is the primary peer (see SECONDARY PEER FOR FAILOVER below) and can be an IP address or an FQDN. | n/a | IPv4, IPv6 |
LOCAL SUBNETS | Enter the local address or subnet in CIDR notation; for example, 192.168.13.0/24 | n/a | n/a |
REMOTE SUBNETS |
n/a | n/a |
EXEMPT SUBNETS |
List of Remote Addresses or subnets to be exempted. Traffic passing through the router to the IP addresses (or Fully Qualified Domain Names (FQDNs)) in this list is sent directly to the Internet, not through the IPsec VPN tunnel. Entering EXEMPT SUBNETS is useful in full tunnel Configurations (0.0.0.0/0 or ::/0), when you need to redirect certain subnets outside of the IPsec tunnel. |
n/a | n/a |
LOCAL AUTHENTICATION ID | You can enter the Local Authentication ID as a text string to identify the router as a VPN client. The Local Authentication ID must also be configured on the remote VPN server (the Sierra Wireless ACM, for example). Alternatively, you can leave the Local Authentication ID blank to use the default WAN IP address. The default WAN IP address would also need to be configured on the remote server/ACM. | n/a | n/a |
REMOTE AUTHENTICATION ID | The Remote Authentication ID configures how the router recognizes incoming traffic. This setting must match the server side. | n/a | n/a |
WAN INTERFACES |
Select the WAN interfaces to use for this tunnel, in order of priority (first to last/left to right). The order specifies the sequence of failover if the highest-priority WAN interface loses connection. You can select default to have the tunnel use the default WAN zone. In that case, the default WAN priority of Ethernet, Wi-Fi and Cellular applies. The Multi-WAN policies Default IPv4 Traffic or Default IPv6 Traffic specify which outgoing WAN interface to use. Please note that even when default is not selected, the tunnel will use the default WAN interface if no other configured WAN interface is available. If you select a custom list of WAN interfaces, then the Multi-WAN Policy for the tunnel in IPsec Policies for Client Tunnels will be created and used. See Multi-WAN Policies below. |
START | Enable the IPsec tunnel and connect to the configured peer. Takes effect after you click CREATE. | Disabled | Disabled, Enabled |
DEAD PEER DETECTION (DPD) |
Dead Peer Detection (DPD) verifies the status of the active connection, and can be configured to take action if the primary/active VPN tunnel goes down. Possible actions when DPD detects a failed connection are:
For more information, see VPN Failover. |
SECONDARY PEER FOR FAILOVER |
When DEAD PEER DETECTION is set to Failover, enter the secondary peer that will take over from the primary peer. This can be an IP address or an FQDN. ![]() |
n/a | n/a |
DPD INTERVAL (SECONDS) | Sets the DPD interval (in seconds). If there has been no traffic during this interval, after five retries (each with an interval of 30 seconds by default) the router takes the DPD action configured above. | 30 | 30–3600 |
IKE REKEY TIME (SECONDS) | Sets how long the VPN tunnel is active, in seconds | 7200 | 60–32000000 |
IKE ENCRYPTION | Sets the type and length of encryption key used to encrypt/decrypt IKE packets. IKE Encryption is the first stage of encryption. More bits in the encryption key increases the security of the traffic, but this also increases the processing load and reduces the number of simultaneous clients the router can support. | aes256 |
IKE INTEGRITY | Sets the type and length of digest used for authentication. | sha256 | sha256, sha384, sha512 |
IKE DIFFIE-HELLMAN GROUPS |
dh16 (modp4096) |
PERFECT FORWARD SECURITY (PFS) | PFS adds additional security because each session uses a unique temporary public/private key pair to generate the shared secret. One key cannot be derived from another. This ensures previous and subsequent encryption keys are secure, even if one key is compromised. | Enabled | Enabled, Disabled |
ESP REKEY TIME (SECONDS) | Sets how long the VPN tunnel is active, in seconds | 7200 | 60–32000000 |
ESP ENCRYPTION | Sets the type and length of encryption key used to encrypt/decrypt ESP (Encapsulating Security Payload) packets. ESP Encryption is the second stage of encryption. More bits in the encryption key increases the security of the traffic, but this also increases the processing load and reduces the number of simultaneous clients the router can support. | aes256 |
ESP INTEGRITY | Sets the type and length of digest used for authentication | sha256 |
ESP DIFFIE-HELLMAN GROUPS | Use this field to select the DH (Diffie-Hellman) group key length used for authentication. The DH group number determines the length of the key used in the key exchange process. Longer keys are more secure, but take longer to compute. Also note that both peers in the VPN exchange must use the same DH group. | dh16 (modp4096) |
VPN LINK MONITORS |
Select one or more configured VPN LINK MONITOR(S) for the tunnel to use. The Link Monitor will restart the VPN tunnel if there is a ping failure. When you have multiple Link Monitors selected, the first Link Monitor that detects a connection failure will trigger a tunnel restart. See Configuring VPN Link Monitors for more information. ![]() |
n/a | n/a |
Select IPSEC FIPS MTU if IPSEC FIPS MODE is enabled (default is 1400; range is 100–1500). This sets the maximum transmission unit size for IPsec packets before encryption.
Select the CONNECTION METHOD if you plan to configure multiple IPsec tunnels in Client mode. The CONNECTION METHOD gives you options for IPsec tunnel failover. The options are:
If the CONNECTION METHOD is Random or Prioritized, select the number of RETRY ATTEMPTS (default is 3; range is 0–10). This sets how many consecutive times an IPsec tunnel tries to connect before the next tunnel is used. Setting RETRY ATTEMPTS to 0 switches to the next tunnel immediately after first connection failure. The interval between retry attempts is set by a default backoff timer. This timer increases after each failed retry attempt from 10 seconds to a maximum of 600 seconds.
Click CREATE IPSEC TUNNEL.
Click CREATE.
The IPSEC STATUS TABLE shows you the main status items. You can click
at the end of each row to view more information.
