Solid Green
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Purple
Off
| RSSI | RSSI | RRSP | SNR | |
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Yellow LED chase pattern
Green LED chase pattern
