    Configuring Wi-Fi
    Wi-Fi Interfaces
    • Wi-Fi AP (2.4GHZ or 5GHz)
    • Wi-Fi Client (2.4GHz + 5GHz)
    For example:
    • The router will provide a Wi-Fi Access Point (using the cellular WAN) in the vehicle for laptops and other client devices.
    • The router will also provide a Client mode interface for when the vehicle enters a depot, where the router can connect to another Wi-Fi network (instead of the cellular WAN). The in-vehicle devices can then take advantage of the Wi-Fi WAN network (for example, to upload video camera or vehicle data to the depot network.)
    To configure an interface as an Access Point, click at the end of the Wi-Fi AP row in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface.
      • WPA — This option appears only when LEGACY MODE is enabled. Requires only a SECURITY PASSPHRASE. (This mode is not recommended.)
      • WPA2 — Requires a SECURITY PASSPHRASE and 802.11w options.
      • WPA2/WPA3 Transition Mode — Requires a SECURITY PASSPHRASE, and automatically sets 802.11w internally as Optional.
      • WPA3 — Requires only a SECURITY PASSPHRASE, and automatically sets 802.11w internally as Required.
      • WPA2-Enterprise — Requires RADIUS Authentication & Acceptance server details; clients that do not support 802.11w will not connect.
      Note: The 802.11w options do not appear for WPA3 or WPA2/WPA3 Transition Mode. For WPA2/WPA3 Transition Mode, ‘Optional’ is automatically used. For WPA3, ‘Required’ is automatically used.
      • Select the RADIUS AUTHENTICATION SERVER to use.
      • Select the RADIUS ACCOUNTING SERVER to use. Note: RADIUS servers must use IPv4 addresses. FQDNs and IPv6 addresses are not supported.
    • Set LEGACY MODE — When enabled, Legacy Mode restores security option WPA (version 1) in the SECURITY MODE list, and supports TKIP encryption for WPA/WPA2 modes. When disabled, only AES encryption is supported.
      • For passenger Wi-Fi applications, enable Client Isolation to enhance security.
      • Disable Client Isolation if you have client applications on the same LAN segment that need to interact with each other.
      • Disabled (default)
    Below the WI-FI INTERFACES table, you can configure the following settings:
      • The DFS CHANNELS setting is unavailable when the Access Point BAND is configured for 5GHz.
      • Enabling DFS may result in delayed connectivity at boot and in the presence of radar.
    • Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality. The Wi-Fi antenna bank can have up to 2 Wi-Fi antennas connected. See the XR Series Hardware Guide for more information about antennas.
      For antenna connectors 1–2:
      • 2x2 enables both Wi-Fi antennas for sending and receiving traffic. Note: When 2x2 mode is selected, ensure that 2 Wi-Fi antenna elements are connected. Clients may not be able to connect if only 1 Wi-Fi antenna is used when 2x2 mode is selected.
      • 1x1 configures one antenna for sending and one for receiving. Select a non-default setting for an access point if you discovered problems with legacy equipment, have fewer than the maximum number of antennas connected, or to improve the router’s thermal performance.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect. The default is 10, with a range of 1 to 10.
    A DISABLE APS ON CLIENT ASSOCIATION switch is below the WI-FI INTERFACES table.
    To configure this feature:
    2. Set the DISABLE AP DELAY to the length of time to wait before disabling the router’s Access Point. If no delay is required, set the delay to 0.
    Configuring Wi-Fi Client Mode
    Tips:
    • Click SCAN NOW to refresh the SCANNED SSIDS table.
    • Rest the pointer on an SSID to view the channel, BSSID and RSSI for each band.
    To use a scanned SSID:
    4. Click UPDATE.
    To create an SSID manually:
    3. Select a SECURITY MODE. For mode WPA2 or WPA2 Enterprise, 802.11w options appear. If required, select an option to enable 802.11w operation. The 802.11w standard uses Security Association Query Requests to ensure that clients are legitimate. Options are:
      • Disabled
      • Required: forces 802.11w operation; the router will not connect to access points unless they have 802.11w enabled. For WPA2/WPA3 Transition mode access points, Optional is used automatically. For WPA3-only access points, Required is used automatically.
    4. Select the PRIORITY. The smaller the value, the higher the priority. Leaving PRIORITY blank puts this SSID at the lowest priority.
    5. Click CREATE.
      When you have multiple SSIDs configured, Sierra Wireless recommends leaving SSID SELECTION at the default Auto (Highest Priority) setting. The router will automatically search and connect to an SSID depending on priority. If priorities are identical, the router will use the closest SSID with the fastest estimated link speed.
    To configure the Wi-Fi client to use only a single, specific SSID, set SSID Selection to “Manual” and then choose the CONFIGURED SSID you wish to connect to.
