The AirLink XR60 router supports the following AMR reports:
For optimum reporting performance, connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the XR60 Hardware User Guide. Many reports will not function correctly if the router is not wired correctly.
Under Services > Telemetry > Vehicle set VEHICLE IGNITION WIRING to Connected to AirLink gateway Ignition Sense input line.
Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
