    Configuring Telemetry
    General
    Vehicle Settings
    VEHICLE IGNITION WIRING This setting determines which input line the router monitors for ignition status. Select the option that matches how the vehicle ignition line has been connected to the router.
    VEHICLE IGNITION STATUS Current vehicle ignition status. Read only. On/Off/Not Available Not Available
    AMR Reports
    ENABLE When enabled, the full telemetry data set is sent to AirVantage so that all Advanced Mobility Reports (AMR) can be viewed. Only displays when Telemetry is enabled. On/Off On
    Custom Reports
    REPORTS
    SETTING DESCRIPTION
    REPORT MODE
    • ALMS
    • MQTT
    • ALMS and MQTT
    GENERATE THIS REPORT AT POWER ON Report that will be generated when the device powers on. Note: Only one report can be selected.
    GENERATE THIS REPORT AT POWER OFF Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated.
    SETTING DESCRIPTION
    EVERY …(SECONDS) Number of seconds between each report interval
    SETTING DESCRIPTION
    AT EVERY SAMPLE OF…
    Options are:
    • Cellular Status
    • Ethernet 1 WAN Status
    • GPIO Input Cumulative
    • Ignition Status
    • Primary WAN
    • Primary WAN IPv4
    • Primary WAN IPv6
    • WAN ready
    • WAN Status
    • Wi-Fi AP 2.4GHz Status
    • Wi-Fi AP Status
    • Wi-Fi Client Status
    Example 2: WAN Ready
    Example 3: Ignition Status
    • Time A: Ignition is DOWN.
    • Time B: Ignition is UP.
    • Time C: Ignition is DOWN.
    Example 4: Primary WAN
    • Time A: Wi-Fi Client is UP and is designated as the PRIMARY WAN. Cellular is also UP.
    • Time B: Wi-Fi Client is UP. Cellular is DOWN.
    • Time B: Wi-Fi Client goes down. The PRIMARY WAN designation is re-evaluated to see if Wi-Fi Client is still the PRIMARY WAN, and it is not. Wi-Fi Client – Down. Cellular – New PRIMARY WAN.
    SETTING DESCRIPTION
    Options are:
    • Cellular Status
    • GNSS Heading (degrees)
    • GNSS Trip Odometer (m)
    • Ignition Status
    • Primary GPIO Input
    • WAN ready
    • WAN Status
    • Wi-Fi AP Status
    SETTING DESCRIPTION
    Options are:
    • Cellular Status
    • Ignition Status
    • WAN ready
    • WAN Status
    • Wi-Fi AP Status
    <RELATIONAL OPERATOR>
    Options are
    • > (greater than)
    • >= (greater than or equal)
    • == (equal)
    • <= (less than or equal)
    • < (less than)
    • != (not equal)
    SETTING DESCRIPTION
    Options are:
    • Cellular Status
    • Ignition Status
    • WAN ready
    • WAN Status
    • Wi-Fi AP Status
    Options are
    • > (greater than)
    • == (equal)
    • < (less than)
    • != (not equal)
    MQTT
    The MQTT section will only display if a custom report has the REPORT MODE set to an MQTT option.
    CLIENT ID Unique vehicle id
    N/A
    • None
    • Username and Password
    None
    TOPIC
    6Q1099009902AC24/test {
      “atp.ser” :
            “t”: 1693258321.3640001,
            “v” : “6Q1099009902AC24”
            “ts” : 1693268920.464
    0: At most one-time delivery. Your data can be lost. No retransmission outside of TCP.
    1: At least one-time delivery. Your data will be retransmitted if needed. The message can be received more than once.
    2: Exactly one-time delivery. The message will be delivered exactly once but the communication overhead is high (multiple acknowledgement messages).
    0
    • ATP FORMAT: ATP FORMAT will use an atp prefix on the data sent to the MQTT broker; for example: atp.GLON
    • NON-ATP FORMAT: Uses the least amount of data over the air; for example: GLON
    ATP FORMAT
    • Individual Timestamp: Timestamp of each sample collected.
    • Report Timestamp: Timestamp of when the report is generated. Least amount of data used.
