AirLink OS is a powerful software application that enables you to configure, monitor, and analyze Sierra Wireless routers and associated applications/accessories. You can access AirLink OS directly over a physical or LAN connection to the device, or on AirVantage.
| Feature | Icon | Description |
| Search |
Click to search for a feature or setting you want to view or configure. Enter a setting name like “LDAP” to find all settings that use that name, or enter a setting value like “IPv6” to find every place that value is entered. Press [ESC] to exit the Search results and return to the main screen. |
| Notifications |
Click the icon to view notifications. Notifications might include… |
| Template |
Click to create, modify or apply a device template. For more information, see Working with Device Templates. |
| Logout |
Click to log out of AirLink OS. By default, AirLink OS logs you out after 5 minutes of inactivity. You can configure the Session Idle Timeout setting on the Services > Web > Session menu. |
| More |
Clicking the More icon allows you to enable Development Mode. |
You can click the arrow (>) in the status bar to view every setting that you’ve modified so far. If you need to revert any of your changes-in-progress, click UNDO next to any of the individual lines or
to revert everything.
