    Viewing and Creating Security Certificates
    All security certificates used on the gateway can be centrally managed. Certificates are used by several functions on the gateway:
    • HTTPS server access
    • VPN IPsec tunnels
    • WIFI Enterprise connection
    Each function will validate the certificate that it is used for.
    Viewing a Security Certificate
    SETTING DESCRIPTION VALUES
    NAME User defined name identifying the certificate N/A
    SUBJECT/DISTINGUISHED NAME The set of values that were entered during the enrollment and creation of the certificate N/A
    TYPE The type of certificate User, CA
    STATUS Status of the certificate Untrusted, Valid, Expired, Not yet valid, Wrong private key, Files missing or malformed, Invalid CA
    Creating a Security Certificate
    The following settings can be used to create a security certificate.
    SETTING DESCRIPTION
    CERTIFICATE Click to upload the certificate file
    PRIVATE KEY Click to upload the private key file
    CERTIFICATE BUNDLE/CHAIN This is currently not used by any functions on the gateway
    The following table describes which fields are required based on certificate usage.
    OPERATION CERTIFICATE PRIVATE KEY CERTIFICATE BUNDLE/CHAIN ROOT CERTIFICATE
    HTTPS Required Required N/A Ignored
    VPN IPSEC Required Required N/A Required
    WIFI ENTERPRISE Required Required N/A Optional
