For automatic Network Operator Switching to work, the router must have radio module firmware for another carrier loaded and displayed in the RADIO MODULE FIRMWARE table. The following steps describe how to ensure that the required radio module firmware is loaded onto the router.
Power the router on.
Log in to AirLink OS.
Go to System > Admin > Radio Module Image Management.
Check if the required RMFW is showing in the Radio Module Firmware list.
Update AirLink OS, as described in Updating AirLink OS Software.The software update will take 1-2 minutes, as indicated by the yellow LED chase pattern. During the update, any specified RMFW images not on the router are loaded onto the router, but are not applied to the radio module yet. The router reboots when the software update is complete. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted in Step 2 above, as indicated by the green LED chase pattern. The update should take about 2-5 minutes, depending on the RMFW version it is updating to.
When the update is complete, you can confirm the RMFW configuration under Status / Monitoring > Radio Module. Check that the FIRMWARE NAME, FIRMWARE VERSION, and FIRMWARE CONFIGURATION have been updated.
Example: If Bell issues a new SIM that has a different PLMN or ICCID than what is defined in the internal database, then a definition using COS to associate the new PLMN or ICCID to an existing carrier firmware is created.
In the above example,
This process is used when NETWORK OPERATOR SWITCHING is set to Manual so that you can manually switch the radio module firmware to a specific network operator. You can check this setting in the Hardware Interfaces > Cellular Interfaces > Cellular section.
Go to Hardware Interfaces > Cellular Interfaces.
Under Cellular > NETWORK OPERATOR SWITCHING, click Automatic to switch it to Manual.
Under SELECT NETWORK OPERATOR, select your desired carrier.
Click SAVE.
The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take about 2-5 minutes depending on the RMFW version it is updating to.
