This page shows you how to configure Wi-Fi for your AirLink XR90 router in Access Point mode and Client mode.
| WI-FI INTERFACE | MODE | ANTENNA BANK |
| Wi-Fi A 5GHz |
Access Point (Default) |
Always uses Antenna Bank A (i.e. “Wi-Fi A” connectors). |
| Wi-Fi AP 2.4GHz | Access Point (Default) |
Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”) |
| Wi-Fi B 5GHz |
Client (Default) |
Always uses Antenna Bank B (i.e. “Wi-Fi B” connectors). |
| Wi-Fi Client 2.4GHz | Client (Default) | Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”) |
For example:
In the Physical field, select the network standard to use.
In the Channel Bandwidth field, select the bandwidth to use (up to 80 MHz). Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz).
Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality. Each Wi-Fi antenna bank can have up to 4 antennas connected. Select a non-default setting for an access point if you discovered problems with legacy equipment, have fewer than the maximum number of antennas connected, or to improve the XR90’s thermal performance.
Best Practice recommendation: If the 2.4GHz and 5GHz AP(s) are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP adresses when switching between the APs.
For all security modes except OPEN, enter a SECURITY PASSPHRASE of at least 8 characters.
For WPA2 and WPA2-Enterprise security modes only, select the 802.11W option.
Note: The 802.11w options do not appear for WPA3 or WPA2/WPA3 Transition Mode. For WPA2/WPA3 Transition Mode, ‘Optional’ is automatically used. For WPA3, “Required’ is automatically used.
Enable AUTO CHANNEL to have the router choose the channel on which to operate.
Enable AUTO BEACON INTERVAL to have the router send periodic messages (beacons) to advertise its availability. To choose a specific interval, disable AUTO BEACON INTERVAL and then manually enter the required BEACON INTERVAL in milliseconds (100 ms is the default).
Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect.
The maximum value you can enter depends on the interface: * Wi-Fi A 5GHz in AP mode supports up to 128 clients (includes clients connected to up to two additional 5GHz SSIDs) * Wi-Fi AP 2.4GHz supports up to 64 clients (includes clients connected to up to two additional 2.4GHz SSIDs) * Wi-Fi B 5GHz in AP mode supports 64 clients (includes clients connected to up to two additional 5GHz SSIDs)
For example (using the Wi-Fi A 5GHz radio in the figure below, which is capable of supporting up to 128 clients):
Configured Maximum Total Allowed Wi-Fi A 5GHz connected Wi-Fi A 5GHz SSID 1 connected Wi-Fi A 5GHz SSID 2 connected Available Wi-Fi A 5GHz = 128
Wi-Fi A 5GHz SSID 1 = 128
Wi-Fi A 5GHz SSID 2 = 128128 50 46 0 32 across all three SSIDs Wi-Fi A 5GHz = 30
Wi-Fi A 5GHz SSID 1 = 20
Wi-Fi A 5GHz SSID 2 = 1060 25 20 5 10 across Wi-Fi A 5GHz and Wi-Fi A 5GHz SSID 2
(Wi-Fi 5GHz A SSID 1 is at max.)
A USE ADDITIONAL SSIDS switch is below the Wi-Fi configuration table.
When enabled, an Additional SSIDS table opens from which you can select, enable, and edit SSIDs (Virtual Access Points — “VAP”s). This allows you to use multiple SSIDs broadcasting on separate LAN segments and configured for different security protocols, if required.
Up to two additional SSIDs can be enabled for each of the access point interfaces (i.e., two for Wi-Fi A 5GHz, two for Wi-Fi AP 2.4GHz, and two for Wi-Fi B 5GHz).
A DISABLE APS ON CLIENT ASSOCIATION switch is below the Wi-Fi configuration and Additional SSIDs tables.
To configure this feature:
To use a scanned SSID:
To create an SSID manually:
