    Configuring Web Settings
    WAN Access Settings
    HTTP ACCESS Configure HTTP AirLink OS WAN access Enable, Disable, Redirect to HTTPS Redirect to HTTPS (RECOMMENDED)
    HTTP PORT Configure HTTP port for Airlink OS WAN access 1 to 65535 80
    HTTPS ACCESS Configure HTTPS Airlink OS WAN access Enable/Disable Enable
    HTTPS PORT Configure HTTPS port for Airlink OS WAN access 1 to 65535 443
    HTTPS CERTIFICATE If using HTTPS, click to select and/or create a security certificate. See Security Certificates Documentation here on how to create a PEM certificate. For HTTPS, only a certificate and private key is required. Certificate, private key and root can be used, but root will be ignored. Root only certificates will not work. N/A N/A
    HSTS HTTP Strict Transport Security Off/On Off
    Session Settings
    SESSION IDLE TIMEOUT The amount of idle time required before the user is automatically logged out and redirected to the login screen. 1 to 1440 mins 5 mins
    MAXIMUM LOGIN ATTEMPTS The number of failed login attempts allowed before the user account is temporarily locked for the length of time specified in the UNLOCK TIME field. Disabling this feature is not recommended. 0(disabled) to 5 3
    UNLOCK TIME The length of time that the user account is locked after the maximum number of failed login attempts. Configured in MAXIMUM LOGIN ATTEMPTS field. 1 to 3600 seconds (1 hour) 120 seconds (2 minutes)
    Remote Authentication Settings
    • LDAP, RADIUS, and TACACS+ are supported for AirLink OS logins, but are not supported by other AirLink gateway services such as Telnet, SSH, etc.
    LDAP Client Settings
    This section enables the configuration of LDAP version 3 servers for use by the AirLink gateway to perform user authentication.
    FILE NAME Required file name N/A N/A
    SERVER Required LDAP server IP address or resolvable domain name N/A N/A
    PORT Port number 1 to 65535 389
    TIMEOUT
    The time limit for the server to respond.
    Note: If the server does not respond during the timeout, the authentication fails and the next enabled authentication mechanism checks the credentials.
    1 to 60 seconds 30 seconds
    ENCRYPTION Encryption type.
    • Off - None
    • On - SSL (Secured Sockets Layer protocol) - Non-standard legacy (pre-LDAPv3) encryption type
    • start_tls - Secure mechanism integrated into the LDAPv3 protocol (RECOMMENDED)
    start_tls
    BASE DN The Base DN is the path in the LDAP tree to the list of users (e.g. dc=sierrawireless,dc=com). This is where the LDAP protocol searches for a matching user to authenticate. N/A N/A
    BIND Choose how the LDAP search is done
    • anonymous - A password is not required to perform requests in the database
    • explicit - A password is required to perform requests in the database
    anonymous
    BIND DN This field only appears if you selected Explicit in the BIND field. The full path of the user authorized to perform requests in the LDAP N/A N/A
    BIND PASSWORD This field only appears if you selected Explicit in the BIND field. Password associated with the Bind DN N/A N/A
    RADIUS Client
    CONFIGURATION FILE NAME Required configuration file name N/A N/A
    SERVER Required RADIUS server IP address or resolvable domain name N/A N/A
    PORT Port number 1 to 65535 1812
    TIMEOUT
    The time limit for the server to respond Note: If the server does not respond during the timeout, the authentication fails and the next enabled authentication mechanism checks the credentials.
    SECRET Shared secret for configured server N/A N/A
    TACACS+ Client
    SERVER Required TACACS+ server IP address or resolvable domain name N/A N/A
    PORT Port number 1 to 65535 49
    TIMEOUT
    AUTHENTICATION PROTOCOL Shared secret for configured server
    • PAP - Password Authentication Protocol
    • CHAP - Challenge Handshake Authentication Protocol The stronger of the two protocols. Recommended, provided it is supported by all the client devices.
    • Login - User name and pasword
    PAP
    SECRET The type of bind used for authentication N/A N/A
